Switch Layout for 14MZ
Reply
Old 11-30-2005, 10:42 AM
bluestratos
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Switch Layout for 14MZ
When I bought my 14mz I had only just gotten back into the hobby so I placed the various fuctions (ie throttle cut, flaps, dual rates etc..) to any switch location that I wanted. I realize now that before I get too many models into the radio I should make sure the switch locations standardized so others can fly with my radio and not become confused. Could someone plz tell me which switch should do what for a more standardized layout.
Best regards,
Randy
bluestratos is offline
Old 12-02-2005, 10:15 AM
bluestratos
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Switch Layout for 14MZ
Anyone? Sure could use help on this one..
Old 12-03-2005, 06:46 PM
BQuartucy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
SWA Elevator triple rate
SWB Rudder triple rate
SWC Flaps,spoilers
SWD Aileron triple rate
SWE Landing Gear
SWF Engine Kill or Trainer
SWG Couple rudder to aileron
SWH Your Choice
BQuartucy is offline
Old 12-04-2005, 04:30 PM
Silent-AV8R
Silent-AV8R's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One of the coolest things about a radio like the 14MZ is that I can put switches where I want them, not where the radio maker thinks they should be. I can even change from 3-position to 2-position, and move them around physically. I have a 14MZAP that I fly gliders, helis and giant scale with. Here's the layout I use:
Giant Scale Aerobatic planes.
SB (3-position above throttle) = Normal/snap/spin flight conditions
SH = engine kill (optical kill switch)
Throttle trim on the left slider (closest to stick)
Timer = CD in switch mode
Thermal duration gliders:
SB - launch/thermal/cruise flight conditions
SE - Aileron to flap mixing (flaperons)
SA - aileron to rudder coupling ON/OFF
Helicopters:
SB - Normal/Idle up-1/Idle-up2 flight conditions
SC (2-position switch) - Throttle hold (autorotations)
SH - Throttle kill
SE - Governor master ON/OFF
Crossed trims for Elevator on everything. T3 control Elevator trim. Much easier to play with without letting go of the right stick.
Notice a couple of things. First, I keep my switches to a minimum. The last thing you want to be doing is scurrying for a switch in an emergency. I use flight conditions rather than dual rates.
Second - notice that I keep things logically consistent from aircraft type to type. The same switch does flight conditions in all 3 types of aircraft. The same switch is used for engine kill, etc. In an emergency I don't have to think about what type of A/C I'm flying since the switches are the same.
In fact this flexibility is one of the things I love most about the 14.
Silent-AV8R is offline
Old 12-05-2005, 11:44 AM
Bax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There really are no "standard" switch positions. Each modeler determines what layout suits them. Some systems with less capability have certain functions "hard-coded" to particular switches. Again, there is no 'standard' layout.
Bax is offline
Old 12-05-2005, 02:51 PM
sirrom
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: bluestratos
Best regards,
Randy
Randy,
That is kind of the point of the futaba radios and their switch assignments. YOU can customize them to what you want instead of having them to what the manufacturer says you should have. I know I standardize all my models the way I like them. Cutoff switch is in the same place, all my high and low rate switches are all the same, but they are where I like them. My setup may be different than yours, and yours different from the next guy and so on, but there really is not a standard way to setup your radio. Just make sure if you let someone fly your plane you are there with them so you can flip the switches for them if they need it.
Patrick
sirrom is online now
