Bvm F-16
Reply
Old 11-12-2002, 01:12 AM
liger0xzoids
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bvm F-16
I am deciding on getting a BVM F-16 or the BVM Rafile jet. I would like to know what people think about it, and I would also like to know what type of radio that I should use. The radio that I have is a futaba FP-T7FG/K AM type that can be switched to FM. I need to know if that will be enough to get some good use out of that jet.
liger0xzoids is offline
Old 11-12-2002, 05:34 PM
Maxime
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bvm F-16
Your radio "could" work, with a few Y-Harnesses and some work. However, I would DEFINITELY suggest you go with a mid-range computer radio ( Futaba 8U, 9C, JR 8 channel... ). A mid range computer radio will give you MUCH more flexibility to adjust dual aileron servos, in-flight mixture, dual elevator servos, exponential etc.
I would avoid an entry-level computer radio, such as the Futaba 6XA or 6XAS, because you won't be able to properly set-up dual elevator servos, and you might need some more advanced functions that only the mid-range and top of the line radios have.
Don't forget to use strong and precise servos (coreless or digital), and a high capacity receiver pack. Those fast jets will drain your Rx pack quickly.
Maxime is offline
Old 11-12-2002, 05:41 PM
MikeL
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bvm F-16
You can't be serious about using that radio with a turbine powered model.
MikeL is offline
Old 11-12-2002, 08:05 PM
liger0xzoids
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bvm F-16
I could get a more powerful radio, but money is a major problem when trying to buy a jet and a radio at the same time, as I barely have enough money left over.
Old 11-12-2002, 08:38 PM
Crashem
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bvm F-16
I would think that with the extremely high cost of a turbine powered jet you would want to wait and put the best radio in it.
I realize best is subjective.
how would you feel if a radio problem totaled you're multi thousand $$$ model
"Penny wise and pound foolish" Is the saying that comes to mind
Have you asked this question in the turbine forum? Last time I was over their I got the Idea that the JR 10x radios were most popular.
Crashem is offline
Old 11-12-2002, 10:27 PM
Maxime
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bvm F-16
You could get used decent radio. I would lean towards a Futaba 8, which should be enough for this jet. Try eBay, or the swap pages on this forum. You might be lucky and find a good system with good servos. And for 35$, Great Planes ( Futaba) will check it out for you. Of course, if you buy from the Internet, do you homework and make sure the person you will buy the radio from is reliable.
Crashem advice is very good.
Maxime is offline
Old 11-13-2002, 02:04 AM
liger0xzoids
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bvm F-16
this is something that I must look into
Old 11-13-2002, 02:48 AM
MikeL
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bvm F-16
How much experience with RC airplanes do you have?
MikeL is offline
Old 11-13-2002, 11:27 AM
liger0xzoids
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bvm F-16
I'm new, but someone is giving me steps, how tos, etc.
Old 11-13-2002, 11:56 AM
MikeL
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bvm F-16
A jet really isn't the best place to start, to put it mildly. To be brutally honest, you won't be able to control it and the money you spend on it will be wasted when it's destroyed shortly after you get if off the ground.
If you're serious about flying a jet of some sort, you'll take the necessary steps to get there. One of those steps is starting out with a trainer plane. Have a look in the Beginner's forum and you'll find a lot of help and useful information.
MikeL is offline
Old 11-13-2002, 08:53 PM
liger0xzoids
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bvm F-16
I'll try, but I hate not having an advantage ovre evreyone else.
Old 11-13-2002, 09:31 PM
SilverEagle2
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default What type of advantage are you looking for?
If it is to say that you destroyed a lot of money worth of model more than anyone else, by all means, get the jet!!!
Otherwise you can give me the money you would spend on the jet and I will buddy box you in on it and you can say you actually got to FLY a R/C Jet.
Seriously, get a trainer and work your way up. You will be extremly happy you did. Besides, a $100.00 trainer airframe is a lot easier to loose if the unfortunate where to happen. You tend not to cry like a little school girl like you would when the $3000.00 airframe plows into the ground.
Those are AIRFRAME prices only mind you. Add in the rest and figure out which you would like to loose.
A wise man at my club said, "If you aren't willing to risk a crash, don't buy, build, or fly it"
Cheers
SilverEagle2 is offline
Old 11-14-2002, 12:08 AM
liger0xzoids
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bvm F-16
I like this tip and I will look around for a plane that I can handle, even though I already know how to fly some planes (anything that you can find from cox, anything in the local toystore, and anything that can be found in a JC Penny catalog).
Old 11-14-2002, 02:17 AM
Joe B.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bvm F-16
as a man of meager means I have no problem in suggesting what I often am forced to face myself... If you can't do it right, don't do it at all. Corner cutting in this hobby is expensive and in some cases dangerous.
- Joe
Joe B. is offline
Old 11-14-2002, 02:38 AM
liger0xzoids
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bvm F-16
I'm hearing good tips now could someone donate me a free 8 ch. radio? (just a joke).
Old 11-15-2002, 03:35 AM
jorgeelizondom
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bvm F-16
You've mastered Cox planes... the JCPennney Catalog toys... and you feel ready for Jets??!! Your really not serious!!??
It's like saying that you mastered foot-powered baby carts and pedal cars so you are ready for Formula 1 racing!!!
If money IS an object, I would strongly discourage you to waste your money on a jet.
Try this: Borrow someone's low-wing fast-flying plane (in the air and flying really high) connected to a buddy box. Make some controlled maneuvers and feel the plane.
Then make your decision to buy the jet.
jorgeelizondom is offline
Old 11-15-2002, 03:57 AM
liger0xzoids
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bvm F-16
may work
Old 11-15-2002, 12:28 PM
Jemo
Jemo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bvm F-16
Buy a real good radio and a cheap plane, work your way up.
Your TX will still be with you when you get there.
Jemo is offline
Old 11-15-2002, 04:24 PM
liger0xzoids
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default f16
I have a radio. Its a futaba FP-T7FG/K AM type.
