Nedd help making a powerfull servo
Reply
Old 12-09-2005, 12:32 PM
perwathne
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Nedd help making a powerfull servo
Anybody know how to make a powerfull servo ?
In the prosess of making a Mini ATV radio controlled, and am planning on using a wheel chair motor as a servo motor for the steering.
perwathne is offline
Old 12-09-2005, 12:58 PM
eaglelope
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Nedd help making a powerfull servo
I'm sure there are sources out there for high-torque servos but it sounds like you want to build one. The thing that makes a motor a servo is the ability to accurately position the output shaft based on some control input.
You'll need to create a way to determine the position of the shaft (RC servos typically use a potentiometer). Next, you need a control circuit that can compare the position of the shaft to the command position it's receiving. You might try taking apart a basic servo to get an understanding of how it works. Obviouldy the voltages and current requirements for a wheelchair motor are different than an RC servo so you'll have to modify the circuit accordingly.
You might also want to read up on some basic controls theory. When you create systems that use feedback (like a servo) you have to be very careful about the relationship of the corrections being sent to the system and the feedback signals. If you're not careful, you can create a condition which casues oscillations or overshoot rather than seeking a specific location smoothly. Look at some footage of early rockets to see what happens when the control ciruits aren't right.
There are other ways to do this (stepper motors, optical shaft encoders, etc). You'll have to decide what fits your skills and requirements. Like many things, there's a lot to it! Have fun!
Mark
eaglelope is offline
Old 12-09-2005, 01:07 PM
mikenlapaz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check this site out: http://www.pololu.com/products/pololu/
mikenlapaz is offline
Old 12-10-2005, 05:36 AM
perwathne
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the input, found a 42 kg ! (583 oz-in) servo at only 64 dollars.
