Futaba aileron mixing question???
my right aileron is on channel 1. i have a 5 channel hitec receiver (555) with a futaba 6exap computer radio. my left aileron will have to be on channel 5. however, channel 5 is my gear channel and is on a toggle switch. my left aileron will only go all the way up or all the way down. any way to electronically fix this problem????? thanks all.
RE: Futaba aileron mixing question???
The 6EXA cannot mix any random channels together. Therefore to use 2 servos for ailerons, a six channel receiver is required. With the 6EXA, you need the servos to be plugged into the channel 1 and 6 slots. The options you have are to either buy a 6 channel receiver, or buy an external mixing board. GWS makes a V-tail mixing board that costs like $15. It can be used for Ailerons, elevons, and V-tail.
