Strange Futaba Mini Servo Problem
My Feedback: (15)
NS, CANADA
I wonder if anyone can help. I have 2 little used Futaba S133 micro servos purchased with a Thunder Tiger "Centurion" park flyer combo. For some reason the servos have stopped operating. On switching on receiver battery servos give 1 mini twitch. On switching on transmitter - NOTHING.
However I find that If I manually turn the servo arm transmitter control will operate just to return the arm to its original position. Both servos exhibit the same identical sympton. Are the servos worth saving or are they junk.
did the servo's used to work with that receiver?? has your tranny switched itself over to pcm modulation?? also, some receivers and speed controllers don't work in certain combinations, maybe your receiver is not compatible with your tranny. also, some synthesised trannies don't work when the same tranny with a crystal module in works fine. try a different receiver with the servo's and see what happens.
