Small Servos for use with Kraft Radios
I use Kraft AM series 80 radios and normally use Kraft Servos. Some other brand servos have had some problems. I need small servos for a project and want to know what brands have been used succesfully with Kraft AM radios.
[email protected]
[email protected]
My Feedback: (27)
MI
hello,
are you using Kraft recievers ? if so you have to use Kraft servos
as they use a much higher signal voltage than modern servos
4 volts as compared to .4 ,I think ,
If your using a R.C.D. reciever then any modern servo will work
just fine as this is what I used to use with my kraft single stick
