Help !! How to setup Flaps / Spoilers - 9Z
Hey guys,
I didnt get a response from the manufacturer support forum, hence I am posting it here.
Please advice how do I setup a tripple switch to operate in this manner. I have a 3D plane with 1 aileron servo on each wing.
1. When the trippe switch is pushed up, the ailerons become spoilers and raises up (I should be able to control the amounts from the menu)...it should also work as ailerons.
2. When in the 'center' position, only the ailerons should work.
3. When in the 'down' position, the ailerons should drop down and become flaps (I should be able to control the amounts from the menu)...it should also work as ailerons.
thanks.
regards
thanks.
regards
