Digital servos vs. coreless?
IN
RE: Digital servos vs. coreless?
Actually no. Most of the hitec low end digitals are 3pole motors, and all futaba digitals beginning with a 3 are cored motors as well. 3050...3151...3152..
hitec 6635...5475...5625... all have "cored" motors
NC
ORIGINAL: Edge 540
From Futaba's homepage:
What is a coreless motor? In a conventional servo, the motor has a steel core armature wrapped in wire that spins inside the magnets. In a coreless design, the armature uses a thin wire mesh that forms a cup that spins around the outside of the magnet eliminating the heavy steel core. This design results in smoother operation and faster response time.
You can read about digital servos here: http://www.futabarc.com/servos/digitalservos.pdf
Jesper
PA
Okay, thanks you guys. I wasn't sure if ALL digital servos were coreless. Looking at Futaba's long list of servos it looked like you could buy digital's that were not coreless. So would you say the coreless servos would be better for 3D or the digitals?
My Feedback: (41)
I'd say coreless are better for 3D. They are faster since there is less inertia in the rotating part of the servo motor so it will accelerate the surface faster.
Also to clear up a few things. Don't confuse analog/digital with 3-pole/coreless. There are coreless servos and 3-pole servos. Then there are digital and analog servos. These are two different features of a servo. So you can have digital that are 3-pole and digitals that are coreless. You can get analog servos that are 3-pole and analog servos that are coreless. The coreless will give the better speed the digital will give you the better centering and tighter holding position error. Put them both together and you have the best servo on the market.
ORIGINAL: pauln28
My Feedback: (31)
ORIGINAL: jfrickmann
No. The 3150 is coreless.
Jesper
ORIGINAL: Edge 540
Jesper
VA
Here's a pretty good pic of a coreless type motor and description
http://www.rccaraction.com/articles/digital_servo2.asp
here's some info on cored motors also
http://www.hitecrcd.com/education/motors.htm
ok, I'm still looking for info myself, here's a nice exploded diagram
http://www.namiki.co.jp/mobile/vibshikumi-e.htm
Just a question here, Futaba has Digital servos with coreless motors and they also have Digital servos with digital motors. What would characterize the digital motor in these servos?
AZ
There is in fact a digital motor. Do a google search and you will find lots of them. They are also known as a stepper motor. R/C servos don't use them though.
AZ
ORIGINAL: dirtybird
So for the sake of comparing apples to apples lets just say in RC servos there is no such animal as a digital motor. Just different pole motors (3 and 5) and coreless motors and two types of amplifiers (digital and analog). Any type of motor can be combined with either amplifier.
John
My Feedback: (13)
MN
What type of servo would be best for a twin engine set-up?
I would imagine they would need some precision.
How about Futaba S9650 or Hitec HS-5245?
Greg
Greg
