an the Throttlle on a Mutiplex Cockpit MM Transmitter
Hi Guys,
Can the Throttlle on a Mutiplex Cockpit MM Transmitter be setup on either right or left stick.
Thanks in advance.
Eddie
Thanks in advance.
Eddie
My Feedback: (194)
MULTIPLEX COCKPIT!
Instructions are in the manual - you have to activate the ratchet for the throttle stick on the side that you want and dial in the proper prgram - piece of cake. Incidentally, it is a fine piece of equipment.
On Cockpit MM throttle can be set on right stick, left stick, or on slider (modes from 5 to 8).
