Robbe RX600 problem
Robbe RX600 problem
Hi,
I have a Robbe RX600 receiver, together with a FC-16 transmitter. I use a 2 cell lipo battery, and lipo speed controller. I use this in a electro plane, rudder, elevator and motor speed. The plane type is Thunder tiger Super Cup EP.
If I power up the plane, and trigger the gas stick the engine starts running on my adjustment on the transmitter. But then only giving a little gas, the engine stops. And i can no longer give power to the motor. I must power off the plane, and put it online again. Then again i can only give little power to the moter before it stops again.
Sorry for my bad english, i hope someone can help me out.
Thank you in advance,
Bastiaan.
Bastiaan.
