9c flap aileron mix
IN
9c flap aileron mix
I messed with this for a long time last night.
I got my ultra stick setup with a 4 servo wing and I want to do some mixes. First, I'd like to have flaps mixed with ailerons, and then lower as flaps only with the flip of a switch. I got it all set up so that the flaps and ailerons work together with switch B down, and only outboard ailerons with switch B up. How do I get flaps to lower with with B up? I'm using 7 channel receiver.
VA
RE: 9c flap aileron mix
I dunno about the 9c, but i know on the 7c you can have either the crow functionality OR the flap-aileron mix
the secret to the setup though, on the 7c at least, is to have the ailerons on 1 + 6, and the flaps on 5+7 ... its backwards from what the manual for the US says...but it helped alot in getting everything else to work for me...
Im still lost as to the aileron/flap mix...i asked this question here a couple of days ago and nobody answered...so it seems that the guys here either dont know or dont care to share, but im betting its the former, as most here are helpfull...
IN
After reading the manual cover to cover - AGAIN I think the aileron differential mix will solve my problems. I assumed that AILERON DIFFERENTIAL, would do just that, put differential in the ailerons. I guess I'm wrong. It appears that it is a 4 servo mix? Doesn't make any sense to me. Oh well. I'll try it tonight.
