Synth. rx required with synth. tx?
CA
Do I need a synthesized rx with a synthesized tx? Can I just use a synthesized tx and set it to the channel the rx is tuned for?
Did some searching and didn't find anything clear on this.
I'd am ordering a JR 9303 and am not sure if I need to order a snyth rx or not. I really wish they'd release their new line of synth rx before early May so I didn't have to get the R2000 10ch rx.
Anyway, thanks!
Anyway, thanks!
My Feedback: (90)
RE: Synth. rx required with synth. tx?
On Hitec, you tune the transmitter module to the same channel the receiver is on. I would bet it is the same for a JR. I am sure the receiver will need to be on the same shift (+) as JR.
CA
That's what I thought. I'd just like to have all my planes on different channels, or maybe get synth rx down the road. Guess I'll go ahead and get it with a standard PCM rx and have the synth tx module.
What do you mean same shift (+)?
Thanks for the reply!
ORIGINAL: TLH101
My Feedback: (16)
GA
Just use JR equipment and not worry about it.
Just say that shift is the reason a JR TX can't control a Futaba PPM RX.
ORIGINAL: RVM
ORIGINAL: TLH101
CA
Yep, getting a 9303 with synth module and the PCM R770. I'll worry about a synth rx later down the road.
BTW, how the heck would I know what channel my rx is on so I can set the tx to the appropriate channel? When I was last in the hobby I think I remember there used to be a little sticker on the receiver with the channel #. Is that still the case?
ORIGINAL: Geistware
ORIGINAL: RVM
