Hitec Eclipse 7 Tx
Hitec Eclipse 7 Tx
Hitec Eclipse 7 Tx. Anyone knows how to change fromMOde 2 to Mode 1.- I have changed the jhoysticks set up, but I am unable to reset the electronics. In my Futaba 6 I can select the Mode.[size=6]
RE: Hitec Eclipse 7 Tx
ORIGINAL: JohnBuckner
Yes it would However will now have crossed trims. While some may prefer this Most today would not as it requires an additional learning curve.
John
John
However I don't understand you cross trims comment. The trim left of the right hand stick will trim whatever is plugged into channel 2, whether that is elevator or ailerons or throttle.
However I guess you would run into probles with things like elevon and Vtail. Yes, I can see that this is not practical.
Oh well, trying to help.
The Eclispe can do certain things the Optic can't, but, for control assignment flexability, the point has to go to the Optic.
Eclispe can can do 4 servo wings, which the Optic can't, for example. And of course there is that 7th channel.
All you need is here, but consider about warranty and if it is worth (the cost):
http://www.rcuniverse.com/forum/m_13...tm.htm#3367982
