Help
Help
I have a Futaba Skysport 6YG and two six channel receivers. Either the recievers or the transmitter is malfunctioning and i cannot tell which as both receivers have the same problem. The symptoms are: Eratic servo movement and shorter range than normal. I think it is unlikely that there is a problem with any of the ariels as all three seem fine. Any suggestions of what is going wrong? Both receuivers have sadly taken a good pounding as i fly combat with my Zagi so anything is possible!
Thanking you in advance
Alex
Alex
