Metal gear servos for $24.99
My Feedback: (77)
http://www.greenmodelusa.com/Digimetalservo.html
ANYONE USE THOSE YET?? THey are called TIGER PRO ...look OK for use in .40-.60 size planes....
Any reports on field use?
thanks!
thanks!
My Feedback: (77)
RE: Metal gear servos for $24.99
Those metal gear servos Feature:
3 pole ferrite, 2 ball bearings, 3 metal gears, 1 resin metal gear
Specs:
Length: 1.6" (40mm) not including mounting flanges
flanges: 1.9" (49.5mm) at center of mounting flanges
Width: 0.8" (20mm) total, 0.39" (10mm) at center of mounting flanges
Height: 1.5" (38mm) not including servo horn
Weight: 1.95 oz (55.2g)
Speed: 0.20 sec/60 degrees at 6V
Torque: 62 oz/in (11 kg/cm) at 6V
Operating Voltage: 4.8V~7.2V
Specs:
Banned
They look a lot like the TowerPro MG995 servos that I reviewed a while back.
Bottom line -- there are better value MG servos out there -- the TowerPro units suffer from a *lot* of overshoot and resulting jitter around neutral. Their quality of assembly is also lacking which will reduce reliability. I've had one failure out of the six I've tested so far.
