Flaperons and Airtronics VG6000
AZ
Hi Guys,
Just installed my reciever and servos. All control surfaces are moving in the right direction. I went to set up flaperons, and they work, but are reversed.
I mean flaps are full extended when the toggle on the radio is full forward. As I push the toggle to position 2 and 3, the flaps retract.
I want to push forward or down on the flap toggle and have the flaps go down.
Did I make sense?
Did I make sense?
BC, CANADA
RE: Flaperons and Airtronics VG6000
Make sure the ailerons are plugged into the correct channels on the receiver and make sure the control rods to the ailerons run from the outboard (wing tip) side of the servo.
If you are using ailerons as flaps, that should solve the problem. If you are using separate ailerons and flaps, you may have to reverse the throws on the flap servos.
