Servos in Firebird XL
Ok, I have 2 HS-55 Hitec servos which I want to somehow put in the fuselage of my Firebird XL.
I completely removed the circuit that was originally inside and replaced it with a receiver and speed
control.
I need some tips on how to make the servos stay at the bottom of the plane, while not gluing
them there entirely. Thanks in advance.
NEO.
control.
NEO.
RE: Servos in Firebird XL
Not sure if they are made the same, but I have a Firebird II that I replace the original receiver/servo in. I took the plastic mount that holds the circuit board to the bottom of the fuselage, and cut a piece of thin circuit-board type material to fit into it, and mounted the servos on that board.
