hitec radio/reciever issues
CT
I am running a Hitec AM HP-2RNB crystal reciever on a frequency of 75.550 with a Hitec agressor radio system in an XTM Mammoth ST. It was all working fine one day and then the next I was having problems. The reciever is not responding at all. I made some of the obvious checks like batteries, wires, antenna but nothing seemed to work. What can I do to figure out what the problem is?
CT
RE: hitec radio/reciever issues
is there anything I can do to determine what is wrong with it. Any tests or trouble shooting? Yes, it may be the crystal but it could also be a number of things. Thanks for the reply.
ORIGINAL: jediguru
You could shake the bejesus out of it with an engraver tip to see if the functionality changes.
You could chase across the circuit board with a voltmeter or scope. Do you have voltage to the receiver board? But there is no magic method.
Bill
