replacement for HS-300 servos
WI
I've had many problems with HS-300 servos. What would be a good, reliable replacement? HS-422, HS-425, Futaba 3004, 148 are some that I am considering.
The HS 422/425 are fine servos with reliability as good as any in the business and are not that much more expensive than the HS 300, lets face it any servo with any manufacturers name on it thats sold for nine dollars is not a good buy. The 300 was a failure and now discontinued I beleve replaced by HS322 or something like that but stick with the four hundred series medium size airplanes and you will be pleased. Another little used Hitec sleeper is the HS 225, superb little guy at half the size. These things are very popular with pylon racers.
John
John
My Feedback: (41)
I sent one HS300 in and it was replaced with a 322. Now another one is bad. Hitec should perhaps provide a credit to go up to a 425BB. The 300's are failing in our club with not that much time on them. That's one negative regarding Hitec and I remain a"user", but would appreciate some action on this.
