pcm
Reply
Old 07-24-2006, 03:25 PM
rc pilot
My Feedback: (25)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default pcm
Is there a difference in crystals from PCM to regular FM or can I run a regular crystal in PCM receiver because mine is not working and I just got a new crystal?
rc pilot is offline
Old 07-24-2006, 03:45 PM
exeter_acres
exeter_acres's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: pcm
same crystal...
make sure it is the same brand as your Rx or Tx....it is dual or single conversion (whichever you need) and truly the correct frequency
exeter_acres is offline
Old 07-24-2006, 05:18 PM
tailskid
My Feedback: (34)
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: pcm
Check your transmitter....it might be on PPM and not PCM. What radio are you using?
tailskid is offline
Old 07-24-2006, 05:32 PM
rc pilot
My Feedback: (25)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: pcm
I have an optic 6 Hitech and it runs on q-pcm instead of pcm but arnt they the same thing ?
rc pilot is offline
Old 07-24-2006, 05:43 PM
tailskid
My Feedback: (34)
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: pcm
I found this on the web site:
"Optic 6 is Q-PCM compatible and works with the Hitec PCM receiver (RCD273)."
So I hope you are using RCD273! I don't know if the tx. works with other receivers....but don't see why not......but it would be better to ask directly on this forum....http://www.rcuniverse.com/forum/forumid_53/tt.htm
which is the Hitec center for questions....
Jerry
tailskid is offline
Old 07-25-2006, 09:56 AM
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: pcm
Each brand of PCM is unique, you can't use a Futaba PCM reciever with anything other than a Futaba PCM transmitter. Its as they say proprietary. If you have a Hitec QPcm transmitter you need a matching reciever.
As for the crystals its all FM so if you match manufacturer of crystal to reciver and get the correct conversion you are good to go.
BarracudaHockey is online now
