futaba questions
Reply
Old 07-28-2006, 06:06 PM
celica_racer09
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default futaba questions
hi,
i have a futaba [link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXENN3**&P=ML[/link].
i have a teu-101bk esc, well im trying to prgram the esc but it said you must turn off the trims to neutral but im not sure if how turn it ot neutral.
and can yall help me program the esc.....?
celica_racer09 is offline
Old 07-29-2006, 01:10 AM
ghendrix01
ghendrix01's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: futaba questions
celeca racer,
Read the manual page 12 for the procedure to set the trims to neutral. Observer the illustrations of the LCD display. The steering has a range of L25-0-R25 (L=Left, 0=Neutral, R=Right) and the throttle has a range of B25-0-F25 (B=Back, 0=Neutral, F=Forward). Just make sure both are displaying 0 (zero). Usually, when the transmitter is new, the trims will be at neutral, unless someone has adjusted them (as in a hobby shop while looking at the transmitter before buying it). You could also just reset the transmitter as described on page 13 of the manual. There are other things to look for during the setup procedure. An example would be that the steering or throttle are not backwards. If so, check out page 13 for the reversing procedure. You could also see if someone at a local hobby shop or RC club could help you.
Good Luck,
George
ghendrix01 is offline
Old 07-29-2006, 09:00 AM
celica_racer09
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thank you thank you thank you very very much
