Futaba Dual Conversion Crystal or not?
Reply
Old 08-01-2006, 03:38 PM
zliu
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Futaba Dual Conversion Crystal or not?
Hi All:
I recently bought a Futaba FP-4NBF Tx with crystal at channel 26. Now I am trying get the right Futaba Receiver with RX crystal to match it.
According to the Futaba FP-4NBF Tx manual, it originally come with FP-R127DF receiver, which is dual conversion receiver.
Can I assume the crystal on the TX is also dual conversion crystal? or how can I find out?
Therefore, I have to buy a dual conversion receiver and crystal at channel 26 to match it.
Please advise.
Thanks.
zliu
zliu is offline
Old 08-01-2006, 04:00 PM
carrellh
carrellh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Futaba Dual Conversion Crystal or not?
Dual conversion or Single conversion applies only to receiver crystals. Your transmitter can control either type of receiver.
If you buy a single conversion receiver, you will need a single conversion receiver crystal (same brand as the receiver)
If you buy a dual conversion receiver, you will need a dual conversion receiver crystal (same brand as the receiver)
Futaba 72 mhz transmitters marketed in the US are "negative shift" so if you buy a receiver that is not Futaba you need to be sure it works with negative shift transmitters.
In the US market, Hitec & Futaba transmitters are negative shift. Airtronics and JR are positive shift. Hitec & Airtronics offer some models that are shift selectable.
carrellh is offline
Old 08-01-2006, 05:38 PM
zliu
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks a lot!
Now, it's depending the receiver I need to use with the TX.
If I go with a Futaba compatiable receiver, if it's single conversion receiver, use single conversion Rx Crystal.
If go with a dual conversion receiver, use the dual conversion RX crystal.
Another question, will the Dual conversion has better range or just less interference?
Regards,
Zliu
zliu is offline
Old 08-01-2006, 09:37 PM
carrellh
carrellh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All of Futaba's single conversion receivers list a range limit of 650 feet. Their dual conversion receivers do not list a range limit; so it is assumed to be "as far away as you can see the model."
carrellh is offline
Old 08-02-2006, 08:25 AM
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's some reading for you
http://www.torreypinesgulls.org/Radios.htm
http://www.futaba-rc.com/faq/index.html
BarracudaHockey is online now
Old 08-02-2006, 09:28 AM
zliu
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you.
I am looking through the links now, it's very informative.
Zliu
zliu is offline
