how do i get my split elevators to move in the same direction?
Reply
Old 08-01-2006, 08:35 PM
SU-13
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default how do i get my split elevators to move in the same direction?
ok guys. this is an emergency(sorta). ok, im setting up dual elevator servos. im using a futaba 9c PCM. and i need help setting up dual elevator servos on my reciever.
PLEASE HELP ME.....
SU-13 is offline
Old 08-01-2006, 08:47 PM
tuwood
tuwood's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: how do i get my split elevators to move in the same direction?
You can do it a couple ways.
Use the built in mix "Ailevator" (page 50 in the manual) and zero out your AIL movements and it will just move the elevators
Grab one of the P-Mix's and do it there. (What I do)
P-MIX1
(ON)
(ELEV>GEAR>)
RATE>-100% -100%
OFFSET 0%
MIX>ON
MAS>2:ELEV
SLV>5:GEAR
LINK>ON
TRIM>ON
SW>A (doesn't matter)
POSI>NULL
tuwood is offline
Old 08-01-2006, 10:25 PM
SU-13
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
if i set it up that way. would i still be able to make the elevators move like ailerons on the flip of a switch?
THis way:
P-MIX1
(ON)
(ELEV>GEAR>
RATE>-100% -100%
OFFSET 0%
MIX>ON
MAS>2:ELEV
SLV>5:GEAR
LINK>ON
TRIM>ON
POSI>NULL
SU-13 is offline
Old 08-02-2006, 07:05 AM
tuwood
tuwood's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
With the Switch setting in NULL (at the bottom) it will just be on all the time. You could technically assign it to a switch, but that would probably be a little dangerous if you bumped it.
I copied those settings from my 30% Edge setup & it works great.
I'm pretty sure the Ailevator mix is where most people do the dual elevator mix. I originally had a 7C & it didn't have an ailevator setting so I used the PMIX's for everything and just carried it over to my 9C.
tuwood is offline
Old 08-02-2006, 11:00 AM
SU-13
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
cool thanks
SU-13 is offline
