Hitec module, Futaba radio, Airtronics receiver
Reply
Old 08-08-2006, 12:39 PM
bigR
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Hitec module, Futaba radio, Airtronics receiver
Hi,
A friend has offered me his older Futaba 7UAps transmitter. I understand that the Hitec synthesized module will work with this radio. However, I want to use the JR/Airtronics positive shift FM deviation. I have many Airtronics receivers and servos that are in good condition. They have the older "reverse polarity" wiring. I do not want to have to replace all my equipment just to use the transmitter.
Question: Can the Hitec Spectra module be used with a Futaba transmitter and send out a signal that matches the JR/Airtronics shift instead of the Futaba standard?
John in Kalifornia
bigR is offline
Old 08-08-2006, 01:18 PM
fizzwater2
My Feedback: (60)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Hitec module, Futaba radio, Airtronics receiver
No, I don't believe so.
fizzwater2 is offline
Old 08-08-2006, 03:40 PM
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In the US Futaba Tx's are negative modulation shift only and your Airtronics Rx's are positive modulation shift only. It makes no differance if you use the legal module in that Tx or a Hitec.
If you want to continue to use your older Airtronics Rx's and upgrade your Tx then you can use any Airtronics, any JR tx or Hitec Optic 6, Eclipse 7 or the older Prism 7x.
John
JohnBuckner is offline
