short rx chip or normal
PA
RE: short rx chip or normal
> normal rx freq chip <
Do you mean the crystal that sets the frequency? Electric planes do not have a unique requirement for crystals different from piston-engned planes.
If this is your rx: http://www2.towerhobbies.com/cgi-bin...JSP9&P=ML#tech
Then Futaba recomends using only the new short crystal and use no channel at or below #16.
I suspect the reason is this may be a single conversion rx and they don,t give you that information. Single and dual conversion rx crystals are not interchangeable and the new short crystal may be an SC crystal.
John
John
