ailavator mixing using programmable mixes?
hi guys. i just wanted to know if i can make the elevators move as ailerons, useing the progammable mixes. because i would like to have it on a switch so i can get a crazy roll rate.
BTW: im using a 9c
BTW: im using a 9c
RE: ailavator mixing using programmable mixes?
If you have the elevators on two channels, then you use mixers as follows:
mixA: Aileron->elevator, link ON, trim ON, set to a switch to turn on/off
mixB: Aileron->2nd elevator channel, link ON, trim ON, set to same switch to turn on/off.
Set the mix +/- and mix percentages to get the elevators to move in the directions you want and in the amount of travel you want.
