ailavator mixing using programmable mixes?
Reply
Old 08-25-2006, 01:10 PM
SU-13
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default ailavator mixing using programmable mixes?
hi guys. i just wanted to know if i can make the elevators move as ailerons, useing the progammable mixes. because i would like to have it on a switch so i can get a crazy roll rate.
BTW: im using a 9c
SU-13 is offline
Old 08-25-2006, 01:30 PM
Bax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ailavator mixing using programmable mixes?
If you have the elevators on two channels, then you use mixers as follows:
mixA: Aileron->elevator, link ON, trim ON, set to a switch to turn on/off
mixB: Aileron->2nd elevator channel, link ON, trim ON, set to same switch to turn on/off.
Set the mix +/- and mix percentages to get the elevators to move in the directions you want and in the amount of travel you want.
Bax is offline
