When do I need to use a voltage regulator?
When do I need to use a voltage regulator? I just bought a 6v 1650mAh NiMH battery and got to thinking or wondering if and when I would need a regulator. Is it just for digital servos or what?
RE: When do I need to use a voltage regulator?
Just look up the listings for the servos you are using to confirm that they are OK at 6V, most servo are good for 6V.
Pete
Pete
CA
I had installed the Futaba Gy401 Gyro and S9254 servo on a newly built heli. The battery I built for it was a five-cell 6.0 v and I had only been flying the heli for a second week when the rudder servo stopped working in flight. Just prior to turning off power to the heli, the servo began smoking violently. I found out that the S9254 does not handle 6.0v, but the gyro does. Expensive lesson. I now use the regulator with all planes and helis when utilizing 6.0v packs.
GA
???...then why not just save the weight and run a 4 cell pack with no reg??
I use 5 cell packs in all my glow planes with no reg.. but as mentioned, double check the servo specs...
I use LiIon with a reg in my gas plane
