14MZ reciever compatibility with a base loaded antenne?
CA
Question, Does the 14 MZ Reciever work with a base loaded antenne such as what is flown on the jets that I have seen, or on IMAC planes.
The antenne wire is usually cut to a 4 inch long length and then attached to the short whip antenne. I have seen them laying parallel and contained with in the fuselage.
Can that work? And if so what is the recommended antenne?
Dan
RE: 14MZ reciever compatibility with a base loaded antenne?
If you're asking about a "manufacturer's recommendation", Futaba cannot recommend that you use anything other than the stock antenna. Basically, if you add a different antenna to your receiver, you're on your own. The manufacturer's performance specifications could no longer be assured, and the warranty would no longer apply if you have operational difficulties.
CA
I am not asking for a Manufacturing recommendation, I am however inquiring if anyone in the modeling public has any experience with a radio antenne whip on the 14 MZ and if any recommendation could be shared.
Dan
Dan
