what transmitters will do this?:
My next project will be a P-38 "special"
The setup would be:
Ch1 left engine
Ch2 right engine
Ch3 left aileron / flaps
Ch4 right aileron / flaps
Ch5 gear
Ch6 elevator
Ch7 left rudder
Ch8 right rudder
Ch9 bomb drop (optional)
I would like to mix the engines to the throttle/rudder for asymmetrical thrust to induce spins the mix would have to be limited on the minimum end to prevent the engines from dieing, rudder mixing for air brakes (crows tail?), aileron / flaps mixed to elevator for loops.
I am putting together a set of Dual Ace 40 wings and building off from them…
The setup would be:
Ch1 left engine
Ch2 right engine
Ch5 gear
Ch6 elevator
Ch7 left rudder
Ch8 right rudder
My Feedback: (90)
RE: what transmitters will do this?:
Airtronics Stylus with the Aero Card will do this. I set all my twins up on seperate channnels with end points and trims. Also lets you mix to a 3 position switch, so you lower one engine to idle while the other is controled by the throttle stick, (your choice of engine at any time). However it is only 8 channels, and you need to use the Stylus receiver as well. I would think that the other 9 or 10 channels on the market would be able to do this, since Airtronics has had all this for about 10+ years.
