Carrying Case Foam
VA
Carrying Case Foam
I purchased a Tower Hobby carrying case for my Futaba transmitter. I like the case fine but the foam is sliced into little cubes. The idea is that you eliminate foam cubes to fit the profile of your transmitter. After a little use, the remaining foam cubes around the transmitter begin to separate. So, in the end, you have little foam cubes falling loose around inside the case.
I conducted several web searches (Google) to find a source for solid foam that could be used to replace my foam cubes. Can't seem to come up with a source selling only the foam. The places I found want to sell both the case and the foam or a foam replacement for the case. Anyone have a good source for purchasing solid, two inches thinck foam that can be cut to fit my case?
