Futaba T6EXA
WA
RE: Futaba T6EXA
If you are referring to ailerons dropping together as flaperons you would use channels 1 and 6 to plug in aileron servos. The manual
describes how to pgrm it as a speed brake. I flip the speed brake switch for flaps on and off. You can use the dial to adjust how much flaperon. info is on pg 28 of 6x manual. 3DAP
