Use JR Radio with Walkera Dragonfly
Old 09-29-2006, 12:40 PM
Flasharino
Flasharino's Avatar
Default Use JR Radio with Walkera Dragonfly
I have a Walkera Dragonfly #5-4 that came with its own 4-ch radio. I just got a new JR XP7202 to use with a new T-Rex. I would like to be able to use the JR with both helicopters. I know that the Dragonfly is on channel 50 because the crystal on the back of the radio says '72.790'. I don't know how to program the JR to use with the Walkera or even if it is possible. Can someone tell me if it is and if so how to do it? Thanks.
Old 09-29-2006, 02:47 PM
pilotpete2
pilotpete2's Avatar
Default RE: Use JR Radio with Walkera Dragonfly
Since the Walkera radio is on 72Mhz it should work, IF the Walkera radio uses positive shift (JR/Airtronics), if the radio is a negative shift radio you won't be able to use the original receiver Good luck,
Pete
