transmitter to pc
transmitter to pc
Hello all,
does somebody here already try to connect a HITEC PRISM7 (not 7X) to a pc on it's serial interface, using the PPM signal from the transmitter.
It seems to me that the PPM pin is the right most when looking at the transmitter back, after removing the RF module.
The ground seems to be on the pin 2 starting from the left.
Is that correct ?
Is that correct ?
transmitter to pc
Isn't it easier to use the PPM signal from Pin 2 of the 6-pin trainer socket or doesn't that transmitter have a trainer socket ?
Steve
Steve
transmitter to pc
Hi steve,
This transmitter have no trainer socket !
But produce PPM and PCM information.
That's why I am trying to use the RF module socket while emitting in PPM mode, but I don't know if it is possible or not with the PRISM7 ?.
