JR R600 Rx
OH
JR R600 Rx
FCC
JR receivers are center tuned so you can change the receiver crystal to any channel you want. I do a good range test after a switch just to make sure but have never ran across any problems.
DEG
DEG
JR R600 Rx
iflyrc24
What do you mean by centre tunned... centre tunned to which channel freq.? I think that if you go from lower band to higher band then it is partial tuned to that new channel with range problems.
JR R600 Rx
what he means by center tuned is that is is tuned in the center and you can use any channel whitout much, if any reduce in range, unlike futaba which has a high and low band so you must stay within certain channels for optimum performance.
