Do I Need a Power Box to Do this?
I want to power my retract servo with its own 6V battery. When I split the servo wire to get the signal from the RX and the power from a 2nd battery pack it will not work, the servo jumps around a little and stops. Servo is good. Battery is good. Have gone back to plugging the 2nd battery pack into the RX and all works - but it is not how I wanted to do this since I am using the 2nd pack for other on-board things too. I didn't think the signal and the power had to be common to one battery - must be wrong. I know I could add a 2nd RX but was hoping to avoid this. Anyone got any ideas on this?
RE: Do I Need a Power Box to Do this?
You can use Futaba's MSA-10 for this purpose. It's a great little device. If you want a DIY I believe you need to make sure that both the receiver and the servo have a common reference voltage (ground). Try using a Y cable and cutting the red wire on it. Then plug it into the receiver and plug the battery and servo into it. Let me know how that works.
