JR PCM 9X II
JR PCM 9X II
Hey guys I just opened my new radio which is mode 1 and noticed that there is no ratchet on the throttle. The radio is mode selectable so maybe they dont factory install the ratchet. Has anyone else encounted this?
Cheers
Cheers
RE: JR PCM 9X II
G'day Mate,
Check in the packing that your radio came in, my 2- X378's came with a smooth throttle ratchet, for heli's, in the TX, & a indented ratchet, in the foam packing.
RE: JR PCM 9X II
my pcm9xseries 2 don't have a ratchet also just the norm I think for this trans plus I don,t use the ratchet makes for the throttle alo smoother
RE: JR PCM 9X II
Yea it does not come factory installed but if you look in the box you will have a piece of metal that you can attach inside you transmitter for the throttle but if u prefer smooth than thats easy.
