DX7 programming for Ultra Stick
VA
I am having the hardest time programming my Ultra Stick 60 on the DX7. I downloaded the Ultra Stick programming instructions for the JR XP7202. http://www.jrradios.com/ProdInfo/Fil...rogramming.pdf and all I can is it's a mess on the DX7. Some of the problems are the right flap moves constantly with the ailerons while the left one stays put, like it should. I had to change a lot of the instructions to get aileron to flap coupling to work on the mix switch. That's the only thing that works properly. Crow doesn't work right and like I said, I can't get just the ailerons to work alone without the right flap. I have been flying this plane on my JR 8103 for 3 years with no problems. Here is my wing setup:
Servo Channel
Right Aileron --> Aileron
Left Aileron --> Gear
Right Flap --> Aux 1
Left Flap --> Aux 2
Has anyone successfully programmed their Ultra Stick on their DX7? If so, I sure could use some help.
Servo Channel
Left Flap --> Aux 2
VA
RE: DX7 programming for Ultra Stick
According to Horizon's instructions, flaperons are not activated so the left aileron does indeed go into channel 5 (Gear). Crow works fine but the aileron to flap mixing isn't quite there yet. All surfaces are coordinated and move in the right direction, but the flaps run out of travel with the ailerons. There is no way to change travel adjustment for Aux 2 that I can find. You can change the Aux 2 travel adjustment on the radio, but it has no effect on the flap.
VA
I understand that under normal circumstances, the left aileron goes into channel 6. But the programming is different for a plane with flaps and crow on the DX7.
