Spektrum receiver connectors
Reply
Old 01-25-2007, 04:33 PM
Jim Messer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Spektrum receiver connectors
I just received my Spektrum DX-7 system, and will begin the process of converting at least nine giant scale airplanes. Got the first one converted today. The biggest problem related to the remaining planes, will be getting enough female connectors that will fit into the AR7000 receiver. At the present these planes are equipped with Deans or Futaba-J's. The Futaba J-s can be made to fit by cutting off the J., but I'd rather not have to do that.
Does anyone know where you can purchase just the female connectors in bulk quantities, with or without pigtails?
Jim Messer is offline
Old 01-25-2007, 05:48 PM
alan0899
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Spektrum receiver connectors
G'day Mate,
Why buy something that adds another connection & chance of failure, when all you have to do is cut off the 'J".
They will still fit your Futaba gear IF you go back, but I don't think you will. I sure won't go back to the old way.
I'm a confirmed DX7 user, now.
alan0899 is offline
Old 01-25-2007, 08:12 PM
d_wheel
d_wheel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It isn't the prettiest mod in the world, but I took a sharp exacto knife and cut off all of the triangle shaped pieces of plastic in the receiver servo bay. I then took a hot soldering iron and made slots for the servo tabs. Worked great for me, but if you want to keep the receiver pristine, your only option is to shave all of the servo connectors.
Later;
D.W.
[img]a7000servoconmod.jpg[/img]
d_wheel is offline
Old 01-25-2007, 09:45 PM
rcguy!
rcguy!'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Are you looking for JUST the plastic housing?
Dave
rcguy! is offline
Old 01-25-2007, 11:03 PM
gwh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just use a small screw driver to release the two plastic tabs that hold the case closed on the pin end. You can then open the case just enough to plug in the futaba connectors with no other mods.
gwh is offline
Old 01-26-2007, 07:13 AM
Bob Pastorello
Bob Pastorello's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Jim Messer
Jim - MaxxProducts sells a lot of this kind of thing. CHeck this link http://www.maxxprod.com/mpi/mpi-4.html , the page before. You will find any combination of stuff you want to try. Personally, I would cut servo wires and solder/splice on the correct Universal ends, but that's just my preference.
Bob Pastorello is offline
Old 01-26-2007, 08:29 AM
DaddySam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dymond RC Modelsports sells the connector sets for $10 per 10 plugs/pins. Here's the link: http://www.rc-dymond.com/index.php?categoryID=36
Sam
DaddySam is offline
Old 01-26-2007, 08:53 AM
Capt Jim
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey guys...the existing servo crimped contact will fit into any housing...Futaba, JR, etc. All you need to do is purchase the JR type of housings to fit the Spektrum rx...or rob them from some old JR type of servos or extension cables just lying around.
It is a simple matter to very carefully...using a needle...lift the tiny plastic finger tab on the housing which holds the contact in place. The contact can then be withdrawn...it will probably just fall out... when the finger tab is slightly lifted. Then discard the Futaba housing and insert the contacts into the JR type housing, noting the proper position for each color wire, and you are done. Just be very careful NOT to lift the finger tab excessively. It is only plastic, and if you stress it too much, it will not return to it's original position, and consequently not be able to accomplish its function...which is to lock the contact into the housing.
This way you avoid making a much bigger job out of it...no additional wires...no crimping...no soldering...and it'll look just like it came that way from the factory!
Note: If you are just snipping off the "J" part of the Futaba housing, you may also have to file a bevel on the edges of the housing so as to create a "D" shape. Look carefully and you will see that the "D" shape is the JR flavor of polarization. Newer Futaba housings already have the "D" shape in addition to the "J" tab...but the older Futabas are squared off and will need a touch with a flat file. Make certain you file it on the sides where the contacts do not show...then you'll have the correct polarity. Sounds like a lot of work, but after doing one, you'll see it is really quite quick and easy.
Capt Jim is offline
Old 01-26-2007, 10:16 AM
pilotpete2
pilotpete2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi All
I would just like to throw my 2 cents in here. Since with universal style connectors there is no risk to plugging a servo in reversed, the positive polarization provided by the "J" connectors while a good thing can't be relied on any more, as so many new micro receivers have end pins that provide no orientation with any plug, making it a good practice to get to look for the position of the signal wire when plugging in servos. Now as far making the cuts for the "J" tab in a receiver, I do think the ideal tool would be a #11 Exacto blade.
Personally I would just cut off the tabs, the last thing I would consider would be adaptors, as they (A) cost, and (B) reduce reliability, heck, I don't even use servo exstensions, but that's just me, hooked on rosin fumes
Pete
pilotpete2 is offline
Old 01-26-2007, 12:23 PM
Jim Messer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys for all the good replys. I believe the solution will be to purchase from Diamond the JR female connector - 10 for 5 bucks. If I read all the replies correctly, these connectors will work in the AR7000 receiver without any other modification.
In my first conversion, I simply cut off the J with a #11 X-acto knife. Worked O.K.
Reply
Display Modes
