Dumb Receiver Question?
Reply
Old 01-26-2007, 08:27 PM
dasintex
My Feedback: (10)
dasintex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Dumb Receiver Question?
To date I have only been using 6 channel receivers, which have the terminal for Battery plus 6 others for Channels 1 through 6; I want to use a small 4 Channel, full range Receiver on a glow powered combat plane; the one in mind is the Hitec 4MG, which has 4 channels 1 through 4 and no battery terminal; however I will only need 3 channels: Aileron#1, Elevator#2 and Throttle#3; do I just plug the battery into the unused #4 Channel; pretty dumb question, eh?
dasintex is offline
Old 01-26-2007, 08:51 PM
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Dumb Receiver Question?
The only "dumb" question is one you are afraid to ask.
Yes you can plug the battery into any unused terminal or if you needed 4 servos you could connect it to a servo with a Y harness then into the reciever, all the positive and negative terminals are common in a receiver its the signal wire that goes off on its own for each channel.
BarracudaHockey is offline
Old 01-26-2007, 10:37 PM
dasintex
My Feedback: (10)
dasintex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks a bunch; I kinda figured that was the case just wanted to be sure; I have some small electric planes that use 4 channel Receivers and there isn't a terminal designated for the battery, it gets tied in through the ESC and Channel 3 Throttle
dasintex is offline
Old 01-27-2007, 08:13 AM
BarracudaHockey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Exactly! With an ESC the power comes IN on the pos and neg wires and the signal goes out on the signal (usually white) wire.
