Voltage Checker
Reply
Old 01-30-2007, 09:52 PM
shundley
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Voltage Checker
Does anybody know where I can get the voltage checker that reads out in digital and you mount it in your plane its about 1 inch by 1 inch
shundley is offline
Old 01-30-2007, 10:22 PM
carrellh
carrellh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Voltage Checker
These are bigger than one inch but might fit your need.
http://www.hangtimes.com/chargers.html
Aviation Concepts On-Board Voltage Monitor, just $42.95
Designed specifically for use mounted on board your aircraft. Dash mount or install in the fuselage side near your switch port. Use for either Rx system or Ignition system voltage display.
Works with any Li-Poly, Li-Ion system as well as with regulated and non-regulated 4.8 and 6.0v Nicad and NiMH systems. The meter comes pre-wired and is compatible with any Futaba J, JR, Hitec or AirtZ system. Plug it into any unused port on the receiver or it can be Y harnessed with any servo or the battery lead. Mounts in a 1 5/16" x 13/16" opening.
OR, Aviation Concepts On-Board Digital ESV w/Load, just $49.95, same size as unloaded version.
carrellh is offline
Old 01-30-2007, 10:27 PM
alan0899
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
G'day Mate,
You can get the same thing, exactly, on Ebay for about $9.00. or check a hobby shop near you, Voltspy, is the name, not expensive.
alan0899 is offline
Old 01-30-2007, 10:34 PM
Josey Wales
My Feedback: (61)
Josey Wales's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.i4cproducts.com/c-volt.htm
Josey Wales is offline
