Jr Reciever, Futaba Radio
Reply
Old 02-09-2007, 01:39 PM
bluestratos
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Jr Reciever, Futaba Radio
Any one know if they are compatable.. I need a 10 channel reciever for my 14MZ but dont want to use the 14 channel they sell as they are very expensive.
Best regards,
Randy
bluestratos is offline
Old 02-09-2007, 01:49 PM
carrellh
carrellh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Jr Reciever, Futaba Radio
Randy, check this thread in the Futaba forum:
http://www.rcuniverse.com/forum/m_5386263/tm.htm
carrellh is offline
Old 02-09-2007, 01:54 PM
bluestratos
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Carrellh, looks like I am in buisness..I wonder how the shift select works, automatic or programmed.. I will look into that.
Thanks again,
Best regards
Randy
Old 02-09-2007, 02:45 PM
MikeL
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not so fast. PCM receivers are proprietary, and only work within the same brand as the compatible radio. Does JR make a 10-channel PPM receiver? That's what you would need.
MikeL is offline
Old 02-09-2007, 02:49 PM
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep shift select (its available in the programming for a 14mz btw) wont help you with pcm receivers.
BarracudaHockey is online now
Old 02-09-2007, 03:42 PM
Krysta
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Randy,
Please double check my post, shift select for the 14MZ is only for FM/PPM
At the moment only the 14MZ has "shift select" which will allow the use of JR FM/PPM and other Postive shift receivers.
We hope to have an update for the 12Z soon that will allow this also.
Thanks, Krysta
Futaba Service Center USA
ORIGINAL: bluestratos
Thanks again,
Best regards
Randy
Krysta is offline
Old 02-10-2007, 09:59 AM
Zeeb
My Feedback: (41)
Zeeb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm not sure if you can use two on/off channels or not, but it's my understanding that both the 9Z tx's and the R149DP rx's are capable of 10 channel operation. Now I know you said that you're running a 14MHz so the tx stuff won't apply but IIRC, the 9Z has that tenth channel function available on switch "D" and the rx must be sent to Futaba for the mod which utilizes the DSC port for that 10th channel...
Zeeb is offline
Old 02-10-2007, 10:28 AM
lrb75
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The best you are going to do with JR is 9ch. The R549X is the most channels they have in an PPM receiver. The 10ch receivers are PCM and they won't work with the 14MZ
lrb75 is offline
Old 02-10-2007, 11:41 AM
davewallace
My Feedback: (29)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Randy,
How about running two 9ch PCM Futaba receivers. This will save the extra channels normally used for dual elevators etc for other uses. You could have eleven usable channels. It may be cheaper too.
Dave
davewallace is offline
Old 02-12-2007, 10:23 AM
bluestratos
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
2 9pcms? How would that work? Wont the radio still only see 9 channels?
Best regards,
Randy
Old 02-12-2007, 12:08 PM
davewallace
My Feedback: (29)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Randy,
You have two receivers running independently. In cases such a elevator where you normally use two channels for two servos, you only use one channel on each receiver freeing a channel. In this case it would be CH 8 freed. You could do the same with ailerons, but you would lose flperon function. You can still get differenial. You just picked up two channels(6 and 8), giving you eleven effective channels. You also get redundancy. It also helps spread the power load on the bus with two rx batteries. You also can have two servos on each of those extra channels and with two locations each. WOW!
Dave
Old 02-12-2007, 07:36 PM
bluestratos
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, I have two spare 9 channel recievers (PCMs) at home, I will try it out.
Best regards,
Randy
