Standard Futaba Horn On A Hitec HS-81
Reply
Old 02-13-2007, 11:31 PM
efish
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Standard Futaba Horn On A Hitec HS-81
Hi, was wondering if anyone else has tried this and whether its safe?
The Futaba horn seems to fit fine on the HS-81 - pretty snug with no play. However, I can't get the hitec horn to fit on a futaba servo - could be that the futaba spline is marginally bigger than the hitec?
Thanks.
efish is offline
Old 02-14-2007, 12:01 AM
mglavin
My Feedback: (31)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Standard Futaba Horn On A Hitec HS-81
The horns are not interchangeble... The spline count and possibly the shaft diameter are different...
mglavin is offline
Old 02-14-2007, 08:37 AM
BillS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: efish
Thanks.
Don’t do that. The horn will slip. The size is different. Hitec is smaller than Futaba. Crash.
Bill
BillS is offline
Old 02-14-2007, 10:19 AM
LesUyeda
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bigger/smaller is not the issue. Hitec has 24 splines, Futaba has 25.
Les
LesUyeda is offline
Old 02-14-2007, 11:50 AM
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You know the mfgs finally got the wiring standardized, why don't they make the splines standardized. Sure would make it great for the aftermarket as well.
TLH101 is offline
Old 02-14-2007, 05:02 PM
fiery
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Airtronics/Sanwa servo arms/wheels will fit JR and vice-versa. Plug'n'play.
They use the same output shaft dimensions /spline pattern on their standard servo's
fiery is offline
Old 02-15-2007, 10:22 AM
LesUyeda
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When Hitec first came out, my conversations with them indicated that it was an oversight on their part, but they were already committed.
Les
LesUyeda is offline
Old 02-15-2007, 11:02 AM
davewallace
My Feedback: (29)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TLH101,
We are in hog heaven now. When I got my first F&M proportional in1966, nothing was interchangable, not even within the same brand. Servos had five wires and most output shafts were square. Some systems were analog and some digital. They were all heavy and expensive. I got mine direct from F&M and it cost me $550. It took over a month to get it. The analog units couldn't find the same nuetral position twice in a row. None had servo reversing, but it was much better then my reed system which used two channels for everthing and even required an extra servo for elevator trim. The manufactures had much less to work with back then, since the IC(interated circuit) wasn't invented until 1969. Everything was made from individual parts. I know that they could do better, they want to make money by selling you more stuff. Thats why a Campac 16K TX memory module cost $80, even though you can buy a 2 gigybyte SD flash card for the same price. The worst case that I can think of is that a $2,000 plus Futaba 14MZ only has high resolution on the primary channels.
Dave
davewallace is offline
Old 02-15-2007, 03:39 PM
Rodney
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hitec, Appolo &Hobbico use the same size arms. Futaba, DAD, GWS, FMA & Tower Hobbies use the same arms. Actually, the odd number of splines are better in that you have a much greater range of fine tuning the mechanical positions by using different quadrants of the servo arms.
Rodney is offline
Old 02-15-2007, 10:14 PM
efish
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks everyone. Knew I'd get a definitive answer here!
Since the servos are mounted on the fuselage and its a 3D type plane, I ended up buying a pair of "Hitec-specifc" anodised aluminium arms. Not sure if they work better but they do look cool!
Thanks again.
efish is offline
