different gears for hs-300
Does anyone know if it is possible to get some sort of 2:1 gear ratio set for the hi-tec hs300 so that it can go a full 360 degrees instead of its standard 180? Or is there any servo of the same size that can be accurately positioned over a 60 deg range?
gearing ratio
Errr... if the servo turns x degrees, and you gear it 2:1, it will turn 2 * x degrees. I want 360 degrees but with the accurate placement a servo allows for.
