Throttle Jockey & Futaba 7CH SETUP
Reply
Old 02-21-2007, 05:28 PM
reaaz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Throttle Jockey & Futaba 7CH SETUP
since it seems that the 7CH doesn't have a governor menu... i am puzzled even after reading the modelavionics site on the 7CH programming for TJ pro. seems i have to use the Gyro channel to set it up.. what i want out of it is to be able to use the throttle normal (governor off), Idle up 1(governor on & 1700rpms) & Idle up 2(on & 1850rpms) AND be able to use the transmitter switch "D" to completely disable it.
thanks if anyone can start to help demistify the setup.. I know i need to use the end point travel for channel 7 to programme the speeds.. but how does this tie into the use of the gyro channel?
reaaz is offline
