Spektrum DSM2 2.4Ghz modules for Futaba and JR announced
#551
RE: Spektrum DSM2 2.4Ghz modules for Futaba and JR announced
Vasek,
Yes the JR module works well in the MX22. I have converted mine with an internal aerial cable mod and use it successfully on helis, jets, pattern and EDF models.
Roger
Roger
#552
Roger, I am baffled.
I did get the DSM2 JR module, only to find there's a current drop of approx 0.5V on the "Charge Indicator Display" in a specific stick position combination (throttle stick near center & other stick on 4 o'clock> full down elev. / full right ailerons)
so I switched the DSM2 module with a fried (he has a JR 9303) >same prob on my TX & not a glitch on his[X(]
BUT there's no prob with my MX22 using regular Graupner module. I've even sent the Tx for a check up to Graupner and it checked OK[X(]
I need some HELP![&:]
#554
TN
As long as the TX has a plug in RF module, the Spektrum module will fit. The transmitter must transmit in the FM PPM mode.
#555
AZ
What am I missing. The Spektrum DSM2 AIRMOD for Futaba 9C WITH a reciever is now $109.00? I will looking at Futaba's TM8 with reciever for $300. What am I missing?
#556
FL
Nothing, they just want Futaba users. How you thing the JR guys themself will feel with the air mod for JR radios at $285.00?
http://www.espritmodel.com/index.asp...OD&ProdID=5692
#557
ORIGINAL: DougV
And yeah, I also have the JR 2.4GHtz X9303 system. Anyone want a bunch of Futaba FM & PCM RXs for cheap?
