Single Conversion & Dual Conversion
RE: Single Conversion & Dual Conversion
http://www.torreypinesgulls.org/radios.htm
Link is Sniped from another thread
Dual Conversion is better than Single.
Read this: www.bergent.net/SC-DC.pdf
Assuming good up to date designs either should operate well. You still can pick certain conditions where one will out perform the other----------my personal preference is Dual Conversion.
If you are flying JR then you'll find (I'm NOT a JR authority) that you'll come close to having the best of both worlds as the first stage is still A,B,C and W---- then it goes to the second stage etc.
My Feedback: (8)
MN
I just read the torrypinesgulls site. If what they say is correct, I have to change my entire concept of how our RC signals are really modulated.
Does anyone else agree with this?
"Likewise, true Frequency Modulation implies servo position proportional to the carrier frequency moved up or down a little, so full left on 72.070 MHz carrier (channel 14) would be 72.075 (carrier + 5 Khz), neutral at 72.070 and full right 72.695 (carrier - 5 Khz). "
Banned
That's a load of bollocks (excuse my French) :-)
There's no direct correlation between carrier frequency and servo position in modern RC gear.
I've not read the article concerned but I really wonder where people get this stuff from.
Xjet, the torrey pines statement is not bollocks, it is true. That is how FM works. The real culprit is our radios claiming to be FM when they are not FM in the full sense.
The full paragraph from torrey pines actually reads
"Likewise, true Frequency Modulation implies servo position proportional to the carrier frequency moved up or down a little, so full left on 72.070 MHz carrier (channel 14) would be 72.075 (carrier + 5 Khz), neutral at 72.070 and full right 72.695 (carrier - 5 Khz). In R/C "FM" there is only full modulation i.e., carrier shifted by 5 Khz or NO modulation (carrier only). R/C FM is identical to wireless data transmission "frequency shift keying" (FSK), at least the computer people don't pretend to be FM."
H.
H.
Irrespective of the technical feedback above, the fact is that Dual Conversion is an improvement, by design. A well made DC receiver will always have better specs than a well made SC receiver, when using the common superheterodyne topology (there are other ways eg: PLL). Whether this is significant to the user is debateable as already stated. I use DC where I can, for peace of mind only.
Sorry Saitofreak, SC can be better than DC under some conditions and in others DC is better than SC. Either method of detection can be very good or very poor depending on the exact design. Cases in point, some of the JR and Berg receivers work as reliably as other receivers do and they are SC. The biggest advantage of DC over SC is their immunity to some intermodulation distortion.
My Feedback: (8)
MN
ORIGINAL: Rodney
I totally agree that comparing SC to DC is totally dependent on the design of each, and in what conditions they are used.
Do we really have to be confined to a 455KHz IF?
I don't agree the Dual Conversion is necesarily more imune to IMD.
AZ
ORIGINAL: CrashGaalaas
Rodney,
ORIGINAL: Rodney
In the US a 455KHZ IF is required to provide the necessary selectivity. You may not need this high selectivity
AZ
Who requires us to put the IF on 455KHz?
Selectivity can be obtained at other frequencies, even at 10.7 MHz if desired.
Its cheap and easy at 455KHz.
Banned
ORIGINAL: HarryC
FSK = digital (binary) frequency modulation of a carrier.
FM doesn't always equal FSK but FSK always equals FM.
In fact, another reason to consider RC FM as a true form of FM is because it only uses *one* oscillator. FSK is sometimes implemented with two oscillators that are turned off/on or switched between. Our RC transmitters have a single oscillator that has its frequency modulated by a varicap - and the limited (slew) rate at which it can change frequencies means that it doesn't just jump from 72.070 to 72.075 but *sweeps* from one frequency to another and back again. If it jumped then it would create all manner of sidebands that would pollute the remainder of the band.
Thats fine, take your pick. The advent of DSP in Rx's has muddied the water somewhat, but hey as long as it works. Enjoy.
455 KHz & 10.7 MHz are 2 Industry Standard IF's and as such the crystal/ceramic filters for these frequencies are in abundance and therefore cheap. You could go ahead and manufacture using your own IF's but then getting the filters made would be horrendously expensive.
