mini receiver for Futaba 9Z help
PA
I am looking for the feather weight receiver that will work with
my Futaba T9ZHP with synthesizer transmitter.
I've tried several receivers and found only Hitec 6 (at .6 oz) will work, but some others lighter ones won't work at all, some will work but no mixing functions.
I also have a Futaba T4VF (Sky Sport 4) transmitter, which 4 channel receiver will work with it (any brand)? The set came with on-board receiver built onto the circuit board in the model.
Thank you
Thank you
Try a Hitec 555 for your 9ZAP. Only negative-shift receivers will work with your 4VF. This means Futaba and Hitec PPM receivers will work.
Again, the FMA M5 will be hard to beat, one of the best small receivers available and can be had for either positive or negative shift.
