European 72MHz frequencies ?
I saw xtals for these 72MHz frequencies advertised in ripmax.com:
1) Brown 72.080
2) Blue 72.160
3) Red 72.240
4) Violet 72.320
5) Orange 72.400
6) Yellow 72.960
7) Green 72.640
Are these European legal frequencies ? There's a 10khz gap between them and the legal frequencies in the USA. Is there any possibility of interference, assuming a good receiver is used ?
Thanks...........
1) Brown 72.080
2) Blue 72.160
3) Red 72.240
4) Violet 72.320
5) Orange 72.400
6) Yellow 72.960
7) Green 72.640
Thanks...........
Have a look at http://www.bmfa.org/JRCUC/internat.html if you want to know what frequencies are permitted in various countries. 72MHz isn't legal at all in most of Europe but 72.080 and 72.240 seem to be allowed in Italy.
Steve
Steve
My Feedback: (30)
Yes, the net is an insect net. The photo is of an old prototype. We have evolved since then. I study the long-ranged movement of economic insects and significant plant diseases which use the storm systems to move hundreds of miles in a single nite.
Elson
Elson
My Feedback: (30)
Electric doesn't cut it. I use 3W power. The propeller is present in so little of the column of air sampled by the net, that damage to insects or fungal spores is not detected.
The airplanes are similar to the idea of the tugboats who move large ships to dock. Way over powered to drag a very draggy device through the air. Deployed insect nets we use generate between 3.5 and 8 lbs of drag depending on size. It takes a lot of engine to overcome this drag and remain flying.
Elson
Elson
Re: &2 mHz in Europe
Originally posted by JohnMac
I suspect this is a typo. Those are 27mHz frequencies I believe
Steve
Those are the OLD ,no longer legal in the US frequencies .
These are some of the very crystals the FCC and AMA were determined to keep OUT of the RC transmitters
The colors were flown on the antenna along with a white ribbon to denote which of the 72 MHz channels the TX was operating on.
