HS645MG Reverse
My Feedback: (63)
RE: HS645MG Reverse
That will not work. All the channels are full. I'll just take one apart today or tomorrow and see. I have done it a couple times already to other Hitec servos so i'll know as soon as i open it up. Also it is the two outer wires on the pot mis spoke earlier.
Pat
Pat
RE: HS645MG Reverse
ORIGINAL: BankYank
Pat
Pat
Which channel do you have the 645MG plugged into?
Whatever channel that is , REVERSE it.
RE: HS645MG Reverse
G'day Mate,
Why didn't you say that in the first place, I could not figure out why it would not work.
But if you are using a separate channel for each flap servo, you should be able to reverse it throught the TX.
